Humming noise and MAP
2013 VOLKSWAGEN JETTA
48,000 MILES • 2.5L • 5 CYL • FWD • AUTOMATIC
CDN IN MEXICO
  • 9 POSTS
I have a check engine light with the code: P0106. The MAP sensor. Suggested a vacuum leak or bad connection or bad sensor. What it the best way to check this and where is the MAP sensor located as I will try to change the sensor first?
When I am driving on the highway (only on highway) over speeds of about 55 to 60 mph the engine starts with a humming sound every few seconds. The speedometer and rpm's gauge fluctuate, but very slightly, the width of the needles. But the noise is apparent and the speed of the engine does 'rev' up and down causing the revving/humming sound. It is not loud but you can feel it and hear it plus the fluctuations in the speed/rpm's but very slightly. What could this be?
Is there a way to adjust the headlights? They both are too high and I recently changed one but they really need to be adjusted and I cant see how.
Thank you very much,
Ryan
Aug 13, 2016 at 2:25 PM
CARADIODOC
  • 34,306 POSTS
For the engine speed fluctuations, when this is occurring, hold the accelerator pedal perfectly steady, then with your left foot, tap on the brake pedal very lightly, or hold it down steady about half an inch. If the engine speed stays higher and steady, the surging is being caused by the lock-up torque converter. The two most common things that will cause that are a mis-adjusted brake light switch, and on older cars with the common sense throttle cable, dirt in the throttle position sensor. Either one can send false signals that you will never feel, but the Engine Computer can interpret as one) you are planning on stopping soon, or two) you are planning on accelerating harder than normal speed variations while cruising. It unlocks the torque converter in response. That is similar to riding the clutch pedal on a car with a manual transmission. The torque converter will relock after one or two seconds when all the conditions are met. That is when you will see engine speed drop about 200 rpm's.
If no one else chimes in for the headlight adjustment, I will research that and try to find the solution.
The MAP sensor will be shown on the vacuum hose routing diagram under the hood. Be aware though that fault codes never say to replace parts or that one is bad. They only indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. When a part is referenced in a code, it is actually the cause of that code about half of the time. First you have to rule out wiring and connector problems, and mechanical issues related to that part.
Aug 13, 2016 at 11:33 PM
