2007 Hummer H3 cab light problem
2007 HUMMER H3
28,000 MILES • V8 • 4WD • AUTOMATIC
BENMO1977
i have problem in my cab light when i close the door the cab light it doesnot shutoff all the time when the car runing i dont know the problem from the door switch or from sensors plz help me to fix the problem if u can thanks
im in north africa there is no gmc dealer in this country thanks
Jun 10, 2009 at 9:19 AM
FACTORYJACK
  • 4,159 POSTS
If this only occurs after using the drivers door, could have a shorting door jamb switch. There are a total of five, including the endgate. Do you also get a 'doors' message on the info center. Try exchanging the drivers door jamb switch with another door that is less used. The drivers and the endgate are most common for failure.
Jun 10, 2009 at 10:13 PM
