2006 Hummer H3 Replace Brake light bulds
2006 HUMMER H3
40,000 MILES • 6 CYL • 4WD • AUTOMATIC
DERFLA77
How so I replace the brake lights
Jul 11, 2010 at 1:46 PM
HMAC300
  • 48,601 POSTS
there may be screws from behind it which hold the lights to the truck. you may have to remove a panel to get it. also check the lens to see if there are screws there as you may be able to take those out to get to the bulbs. If you get to the socket in back it will turn then the bulb will pull out.
Jul 11, 2010 at 2:27 PM
