2006 Hummer H3 Front Directional Light Bulb
2006 HUMMER H3
CHRISDESIMONE
Electrical problem
2006 Hummer H3 All Wheel Drive Automatic 32300 miles
The front directional bulb went out. I have removed the grille, but can't tell how to access the bulb ro replace it. Please help.
Mar 27, 2010 at 3:42 PM
CHRISDESIMONE
please tell me how to access the bulb to replace it. I have already removed the grille
Mar 27, 2010 at 3:55 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated Daytime Running Lamp, Park and Turn Signal Lamp and Bulb Replacement - Front Preliminary Procedure Remove either the RH or LH front wheelhouse panel. Disconnect the electrical connector from the daytime running lamp (DRL) bulb socket. 1...Socket, Daytime Running Lamp Bulb Tip: Twist the lamp socket counterclockwise to remove. 2...Bulb, Daytime Running
https://www.2carpros.com/forum/automotive_pictures/266999_hum_1.jpg
Mar 28, 2010 at 6:58 AM
CHRISDESIMONE
Dave,
Thank you so much for your reply. Please tell me how to remove fasteners that hold wheel well in place.
Thank you, Chris
Mar 28, 2010 at 9:01 AM
DAVE H
  • 13,384 POSTS
Wheelhouse Panel Replacement Fig. 20: Wheelhouse Panel Replacement
https://www.2carpros.com/forum/automotive_pictures/266999_hum_2.jpg
Wheelhouse Panel Replacement Lift and support vehicle. Remove the front wheel. Remove Wheelhouse panel screws/retainers (if fitted with push pin retainers .. pull center pin of retainers from outer ring) 1...Retainer, Front Wheelhouse Panel (Qty: 10) 2...Panel, Front Wheelhouse
Mar 29, 2010 at 3:34 AM
