2008 Hummer H2 serpintine belt
2008 HUMMER H2
18,000 MILES • 6 CYL • 4WD • AUTOMATIC
SCOTT HUNTER
I replaced my alt with high out put one and now am having hard time putting belt back on. HELP
Scott
Jul 31, 2009 at 1:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_768.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_204.jpg
Jul 31, 2009 at 2:14 PM
FACTORYJACK
  • 4,159 POSTS
High output alternators generally have a larger pulley on them that would explain the fit problem. Compare your alternator(o.e.) pulley size with that of the H.O. The next thing is finding a longer belt, the part number of the OE belt will correspond to a size in millimeters, and you can add what you think you need by looking at similar belt specifications. It will take some trial and error. A parts supplier should be able to assist, they will have more options. A dealer may be able to give you the specs on OE belt, but may only have belts for specific applications.
Jul 31, 2009 at 10:11 PM
