2005 Hummer H2 Key won't turn
2005 HUMMER H2
67,000 MILES • V8 • AWD • AUTOMATIC
GARYPBG
I had an ignition switch problem, I changed the switch and now the key will not turn to the start position. It seems that it is stuck
Feb 17, 2010 at 7:31 PM
FACTORYJACK
  • 4,159 POSTS
Your switch was probably installed out of reference. You would need to remove it and retime it, you can do this by moving the gear. Without being able to put my hands on it, I am not really able to help you retime it, it is more or less trial and error.
Feb 17, 2010 at 11:40 PM
