2004 Hummer H2 Battery was replaced and now the Sat Nav scr
2004 HUMMER H2
KBARNES1
Electrical problem
2004 Hummer H2 V8 Four Wheel Drive Automatic 90K miles
After having the battery changed, the screen on the music system which inludes the sat nav is blank. Does the system need to be reset and if yes how? The radio etc is working just no screen. Thank you
Mar 12, 2010 at 8:19 PM
FACTORYJACK
  • 4,159 POSTS
Typically, there is no special procedure that needs to be performed. Is this a factory navigation unit? You can try removing the 15A radio fuse in the underhood fuse box, and reinstall it after a couple minutes to see if it corrects it, kind of works like a reboot. If it is aftermarket stereo, I would still try removing the power.
Mar 12, 2010 at 11:03 PM
