Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Hummer
H2
Engine Cooling
Thermostat
2003 Hummer H2 thermostat
2003 HUMMER H2
88,000 MILES • V8 • 4WD • AUTOMATIC
MSHOPEY
MEMBER
1 POST
FOLLOW
do i need to drain the antifreeze first? never seen the thermostat on the bottom radiator hose.
Oct 31, 2009 at 11:57 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
Yes, you will need to drain the cooling system before replacing the thermostat.
Oct 31, 2009 at 10:29 PM
FACTORYJACK
CERTIFIED EXPERT
Where the lower hose meets the water pump is where the T-stat is.
Nov 4, 2009 at 9:29 PM
