huge blue smoke
1999 RENAULT CLIO
247,506 MILES • 1.2L • 4 CYL • FWD • MANUAL
SULEIMAN MOHAMMED HONG
the problem all started when changing the oil it started bringing some smoke and i change the oil to total and it stop smoke. but after ten days is started over heating and the engine coolant escape while there is no leakage and the flow the a huge smoke. please what do you is the cause of it?
Mar 13, 2017 at 12:01 AM
MHPAUTOS
  • 31,937 POSTS
blue smoke is oil burning, firstly check that the oil is not over full. also, what grade of oil did you use? was it the same that has been used in the past and is it synthetic or mineral oil?
Mar 13, 2017 at 12:26 AM
STEVE W.
  • 15,113 POSTS
So you changed the oil and it stopped smoking, then it overheated and blew out the coolant. Now it is blowing smoke again. If it is bluish smoke it is oil burning, if it is white smoke it is coolant being burned. Blue smoke could be valve stem seals or rings. White smoke is likely a bad head gasket from overheating.
Mar 13, 2017 at 2:07 AM
