Actually, this is my mistake for not reading correctly what you wrote. Toyota is one of the few manufacturers that still use a pressed-in front wheel bearing design, but the aftermarket suppliers have made preassembled assemblies available. There can be all kinds of variations with all kinds of different part numbers. Too many, in fact, to be concerned with those numbers. I do see the same number is listed as one of the choices for both years from one of the suppliers.
What is important with these bearings is the number and spacing of the wheel studs, the spacing of the mounting holes on the back side, and the number and size of the splines on the half shaft. If the new bearing assembly bolted on and the wheel fit, the bearing is the same.
You can do the same as I described before. On the Rock Auto site, click on "Toyota", then on the drop-down menu, click on "2009", then your model. The hub and bearing is listed under "Brake / Wheel hub", near the end of that list. Click on "Wheel Bearing & Hub", and you'll see the products listed from a variety of manufacturers and suppliers, each with their part numbers. I have to write some of the part numbers down because there's too many to remember.
Next, look up the same parts under the 2011 listings and see if they show the same part numbers from the same suppliers. I noticed one was the same for both years, so the year should not be an issue.
I also noticed the rear wheel bearings are different, but the only difference is the wheel speed sensor for the anti-lock brakes. The connector is at a different angle, but you can use the left bearing on the right side. It will get the job done by just rotating the plug a little. When you don't know that, you can only go by the different part numbers, and that would incorrectly tell you the parts can't be interchanged.
You should also be aware, in this case, Chrysler again, when a significant improvement is made in a part, especially one that they purchase from a different supplier, it gets an entirely new part number even though it replaces the old version perfectly, with no modifications. They'll sell the old version first until they're gone, then start selling the new version. Either one can be used, but you may only find one of those part numbers listed on some web sites.
Getting back to your comment about the half shaft dropping out of the transmission, that isn't related to the wheel bearing. That's due to the spring inside the inner cv joint. That joint has to collapse to change length as you turn and go up and down on bumpy roads. The spring also pushes the inner CV joint into the transmission to hold it there. Back in the '90s that replacement spring cost $3.00 and took about an hour to replace.
It's also not unheard of that inner joint pulling apart while the wheel bearing is removed. If it doesn't go back together properly, it's unlikely you'll get it to go back into the transmission. That will be obvious long before the wheel is installed and you try to go for a test drive.
Jun 10, 2023 at 11:18 AM
