Being stumped by a master cylinder change on the car listed above 3.0. the problem is that i cannot properly bleed system due to ABS module being closed,thus hindering proper repair.i have been reading about using a scanner tool to command comp to open valves to allow proper bleeding. i'm only a parts changer due to my own car dilemmas and i do own a Bosch 1100 diagnostics tool, however i'm not sure if this will be able to fix problem and if so what are the steps to use to command the ABS? i have only used it for code reading and have no clue how to use it in this manner.
Jun 1, 2020 at 5:44 PM
