Cranks fine, but no start at all. I am assuming bad fuel pump (or devices that control pump), so I have checked fuse (20A; slot F56, up under glovebox) the only fuse or relay in the owner's manual referencing the fuel system (listed as "fuse pump supply") and it's not blown. I thought cars also have a fuel pump relay?? --- but cannot find any reference to one for this car, in the owner's manual or with a really exhaustive search with Google and YouTube. Does the fuel control module (under the rear seat, passenger-side) perform this function instead?? If it was a [typical] relay, I was going to simply swap with another 20A relay from fuse box to test it, but of course there's only one fuel control module so that trick won't work. Is there any way I can know for sure, with my voltmeter, if the fuel control module is bad, before I just gamble and maybe waste almost a hundred dollars unnecessarily? Thanks!
Feb 13, 2025 at 12:28 PM
