When you disconnect the battery, the Engine Computer loses its memory. All the fuel trim numbers and sensor data will start to be rebuilt as soon as you start the engine, except for "minimum throttle". Until that is relearned, the computer won't know when it has to be in control of idle speed. The engine may not start or run unless the accelerator pedal is held down 1/4". You won't get the nice idle flare-up to 1500 rpm at start-up, and it will tend to stall at stop signs.
To meet the conditions for the relearn to take place, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals.
Aug 30, 2020 at 10:50 AM
(Merged)
