How to reset my alarm system
1996 JAGUAR XJ6
300 MILES • AUTOMATIC
JAGALL72
My car will not start. how do I reset my alarm system? I think it shut the car down.
Feb 22, 2017 at 2:31 PM
STEVE W.
  • 15,113 POSTS
This is a generic guide that you can try.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Specific to your car is that the alarm is a different system that the immobilizer. The common problems are a bad transponder key, bad transponder receiver, and bad connections. One way you can sometimes tell if it is the immobilizer is to watch the check engine light. Turn the key on, all the dash lights should come on and the CEL will be on. If it goes out as soon as the other lights do at the end of the bulb test, the immobilizer has a fault and will not allow the engine to start. That would mean taking it to a dealer so they can scan the system to locate which part is bad. Many of them require programming that they can do.
Feb 26, 2017 at 2:29 AM
