How To Reset Carriage Control Module after car battery replacement
2001 SATURN L200
18,000 MILES • 4 CYL • 2WD • AUTOMATIC
KEN ANAME
  • 7 POSTS
I need to reset carriage control module on car so it can pass county emissions test. Car battery was replaced in April and as a result the under carriage module lost memory.
Aug 17, 2016 at 10:50 AM
SATURNTECH9
  • 30,869 POSTS
You need to be more clear on what your asking.Are you talking about the engine control module? If you are how many miles have you driven it since the battery was replaced? Also are saying the monitors are set?
Aug 17, 2016 at 12:34 PM
KEN ANAME
  • 7 POSTS
Can you email me so I can send you pdf of test result?
Aug 25, 2016 at 7:53 PM
SATURNTECH9
  • 30,869 POSTS
You can't a picture of it to the image kink on this question?
Aug 25, 2016 at 10:07 PM
KEN ANAME
  • 7 POSTS
Hope this file can clarify issue I'm having.
Aug 27, 2016 at 11:11 AM
SATURNTECH9
  • 30,869 POSTS
I can't zoom in to read it.
Aug 27, 2016 at 7:51 PM
KEN ANAME
  • 7 POSTS
says obd inspection monitors not ready: evaporative system
oxygen sensor. how do i resetwithout taking car apart?
Aug 28, 2016 at 1:05 PM
SATURNTECH9
  • 30,869 POSTS
So you only have two monitors not set?
Aug 28, 2016 at 2:14 PM
KEN ANAME
  • 7 POSTS
That is correct. What do I do?
Aug 28, 2016 at 5:30 PM
SATURNTECH9
  • 30,869 POSTS
So again how far has it been driven since the battery and codes have been cleared?
Aug 28, 2016 at 7:22 PM
KEN ANAME
  • 7 POSTS
It has been driven about 20 miles since battery has been changed. Can't be driven further until registered to be on road.
Aug 29, 2016 at 9:00 AM
SATURNTECH9
  • 30,869 POSTS
20 miles isn't far enough to set the monitors it will have to be driven Alot further.To set the evap monitor you will have to have 3/4 of a tank or more.Can you get a temporary moving pass?Otherwise your never going to get the monitors set.
Aug 29, 2016 at 6:05 PM
KEN ANAME
  • 7 POSTS
How many miles does it need to reset. Approximately? I'll see what I can do.
Aug 30, 2016 at 12:00 PM
SATURNTECH9
  • 30,869 POSTS
Honestly it varies from car to car even the same make and models .Some pretty quick some take more time.For the evap make sure it's got a 3/4 tank of gas or fuller to set the evap monitor.
Aug 30, 2016 at 10:18 PM
