Not sure of location of the water sensor or oil sensor sending units. Dashboard gauges for oil & coolant do not work, but the fuel gauge works. Would like to replace these sending units so all the gauges work. Not a fuse problem as all have been replaced. I see two electrical units plugged into the engine underneath. One right above the oil pan on the right side. The other unit is right underneath the intake manifold, but I can't seem to remove the housing.
Aug 25, 2013 at 1:00 PM
