Here are the instructions with a diagrams below:
- Remove engine compartment panel.
- Remove generator.
- Unplug plug connection (10) of oil pressure sensor (11).
- Unbolt oil pressure sensor (11) and remove with seal (12).
Tighten to: 15 Nm.
- Unbolt oil pipe (8) of air-oil cooler at oil sump.
- Unbolt oil lines (7) and (8) of air-to-oil cooler at oil filter (5).
Tighten to: 7 Nm.
- Replace seals (9).
- Unbolt oil filter (5) at crankcase.
Tighten to: 25 Nm.
- Remove oil filter (6) upward.
Installation Note: Clean sealing surfaces.
- Replace gasket (5a).
- Install in reverse sequence, observing tightening specifications and the installation note.
- Check oil level in engine, adjust to correct level.
- Run engine, check for leaks.
Oct 17, 2018 at 10:59 AM
