Good evening.
Do you have manual A/C controls or automatic climate control? it does make a difference.
I have attached a picture for you of the automatic climate control since you have dual controls. it is under the left side of the dash on the side of the heater case.
https://www.2carpros.com/articles/replace-blend-door-motor.
If you have manual controls then it is a different story. the dash has to be removed to access the actuator.
The labor for the automatic climate control is .8 hours or about fifty minutes.
The labor for the manual is 6.5 hours.
Dec 29, 2018 at 5:41 PM
