The bolts have come out & lock rod is missing & door will not close shut. The drivers door the bolts came out of the door clasp that hits the striker & keeps it closed & the lock rod where you used to open & lock the door pressing the electric switch disappeared. The clasp is like a jaw see photos & in closed position. The key will turn but it does nothing to open the door.
The door will no longer stay closed. Photos show last one is the other good side & all other ones are the problem. I have no bolts & need to know where to purchase & how to fix. Yellow is the string I am keeping it closed with until I can fix. How to repair door latch on drivers side the bolts have come out & lock rod is missing & door will not close shut. The door handle on outside is OK not loose.
May 21, 2014 at 2:12 PM
