Okay, there is a small retaining clip on the inside of that plastic handle, which needs to be removed first. I'm looking for information on the mechanical part of the seat, everything I've given you so far is for the Coupe,
Thats the Seat Recliner Handle, then under that cover (after the handle is removed) is the Bezel and bracket assembly, except the information on the seats is pretty vague. There are 2 different setups, it looks like AQ9 and W2E. Give me a minute to go through all this information. It's saying to remove the entire seat, but that seems a bit extreme unless the whole bracket needs to be replaced. I'm just wondering if something got stuck down there that's preventing the handle from moving.
This is what I was worried about, before removing any seats, there is an SIR warning, this refers to setting off the airbags by accident. I've seen this happen because there was a Supplement restraint system component attached to the bottom of the seat.
Okay, the second picture is the W2E and the third picture is the AQ9 design.
Feb 26, 2022 at 12:52 PM
