1.3L engine that camshaft is seized in, breaker bar cannot turn camshaft even with all
valves no longer attached. Distributor casing removed and gear pulley removed from each end of cam. Manual seems to indicate that you can just push the camshaft out in the direction on the distributor side but even tapping bolt head on other side does not move it. 1) how to get camshaft out? 2) what could cause this
Mar 21, 2014 at 1:19 PM
