how to remove oil oraface for the timing chain
1995 CHEVROLET S-10
190,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
PAULBECK
How do I get the oraface out to replace with a new one?
Sep 3, 2014 at 2:23 PM
HMAC300
  • 48,601 POSTS
you don't need to remove it, if it's plugged use a piece of wire to unplug it . it is driven in and held with Loctite. if you really need to take it out remove lifter galley plug from back of engine and drive it out. if engine not out try putting a tap in it or a small punch and hit one side to twist it then grab it and pull it out
Sep 3, 2014 at 3:18 PM
PAULBECK
Thank You
Sep 3, 2014 at 4:15 PM
