How to remove grooved nut from right rear axle to get to wheel bearing
2000 HYUNDAI ELANTRA
116,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
PLUMBERJOE
I have a rubbing, grinding noise coming from right rear wheel every since I changed the caliper that locked up and put new brake pads on
Apr 12, 2016 at 4:12 PM
MHPAUTOS
  • 31,937 POSTS
Time to strip it down and start again, check wheel bearing for any play or noise when spun up, attach rotor and check for run out, attach caliper mount ensure alignment is ok, check caliper for serviceability and if all ok and attached with pads fitted there should not be any problem, start again and look carefully at each component in turn, that way you should see any problem.
Apr 17, 2016 at 2:55 AM
