How to remove flasher relay?
2003 TOYOTA CAMRY
170,000 MILES
VLAD KRIM
  • 9 POSTS
I cannot hear my turn signals.
So, I assume I should replace flasher relay.
I'm not sure how to remove it.
Any help will be greatly appreciated.
Where to buy a replacement.
Pictures are attached.
Vlad
Mar 23, 2022 at 11:55 AM
SQM
  • 6,383 POSTS
The flasher relay simply pulls out of the socket.
You might have to use a needle nose plier to pull it out, it could make it easier.
These relays are available at many of the local auto parts stores like AutoZone, O'reillys, Napa etc.
I have attached diagrams below for your reference.
Thank you.
Mar 23, 2022 at 3:00 PM
VLAD KRIM
  • 9 POSTS
Thank you so much.
I can tell you are professional. thank you for sharing your knowledge.
Mar 23, 2022 at 4:38 PM
SQM
  • 6,383 POSTS
You are welcome.
Thank you for using 2CarPros.
Mar 23, 2022 at 11:16 PM
