How to remove Crankshaft from the block engine, dismounting and mounting procedures?
2016 AUDI Q7
17,865 MILES • 3.0L • 6 CYL • TURBO • 4WD • AUTOMATIC
ANDRIN ATEM
  • 393 POSTS
Please can I have a guide on how to dismount the crankshaft from the engine block and mounting, I need to resurface the block.
Jun 6, 2024 at 4:17 AM
I would ask the fine people over on Reddit, they are great.
Jun 6, 2024 at 8:22 AM
Can you please double check the year?
2007 Audi Q7
Overview
Production November 2005 - 2015
Model years 2006 - 2015
Jun 6, 2024 at 8:37 AM
ANDRIN ATEM
  • 393 POSTS
It’s a 2016 Audi 3.0 supercharged Quattro.
Jun 6, 2024 at 9:55 AM
Gotcha, they don't show us much for this, I would get a factory manual for the car.
Crankshaft Bearing Journal Diameter
mm 65.000 - 0.022 - 0.042
Crankshaft Connecting Rod Journal Diameter
mm 56.000 - 0.022 - 0.042
Sorry we were not more help. Check out the images (below). Let us know if you need anything else.
Jun 6, 2024 at 4:34 PM
ANDRIN ATEM
  • 393 POSTS
Yes it does, thank you.
Jun 7, 2024 at 7:41 AM
You are welcome, please use 2CarPros anytime we are here to help.
Jun 7, 2024 at 10:19 AM
ANDRIN ATEM
  • 393 POSTS
It’s always my sure bet, no mistakes bro, thanks always!
Jun 7, 2024 at 11:45 AM
ANDRIN ATEM
  • 393 POSTS
May I ask an important question, Ken?
What happens when you do not follow the loosening sequence of the top cylinder of Audi W7 3.0T, does it have an effect on the block or the top cylinder?
I need to know, the technology behind this. For the torque sequence I understand, but for the reverse loosening sequence I need to learn something very important. Thanks, waiting for a positive reply.
Jun 10, 2024 at 11:01 AM
ANDRIN ATEM
  • 393 POSTS
I almost forgot, on this Audi, how to verify if your car water pump works well, I am just making sure I got everything in place correctly.
Thanks!
Jun 10, 2024 at 11:26 AM
Yes, you need to follow the disassembly instructions to avoid damage to the engine components which is similar to the assembly instructions only in reverse. Please start a new question for the water pump issue. Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Jun 10, 2024 at 11:46 AM
