If it is the same as those from the late 1990's, it unscrews. Look for two flats, about a half inch long, about an inch from the steering column cover. If it is tight enough to require a wrench, that is the place to use it. You will need one smaller than 1/4". You can find wrenches that small in ignition wrench sets. You can also wrap a rag around the shaft, (about two or three layers), then grab it with a pliers.
Dec 10, 2016 at 11:05 AM
