I believe i have an obstruction in my door blend arm area and it will not move from dash and floor. I hear a loud clicking noise coming from the actuator and also can feel it if i put my hand on it so i know its the one. I do believe a micro-sd adapter fell into my vent from above (dash) and now it is stuck.
I disconnected my battery and then reconnected my battery moments before this began to happen. i do not know if this is related, i have not taken the actuator off and tested to see if the blend arm will move.
My question is how do i get into the blend door arm compartment? I need to remove the obstruction or at least look to see because the actuator is in a very tricky spot for removal. also, i did try to turn the metal circle on the actuator (not sure if it moves ), but it will not turn.
Thank you very much.
Jan 22, 2017 at 5:45 PM
