How to remove my console armrest lid
2013 FORD EXPLORER
43,215 MILES • V6 • AUTOMATIC
HEATHER SHILLINGTON-PINKERTON
  • 8 POSTS
I need to recover my armrest can you help me remove it?
Apr 23, 2016 at 12:08 PM
HMAC300
  • 48,601 POSTS
See picture diagram it shows four screws.
Apr 23, 2016 at 4:42 PM
  • 8 POSTS
Thank you for the specs, I cannot get those screws. Frustrating
Apr 24, 2016 at 6:36 PM
HMAC300
  • 48,601 POSTS
the screws may be torx bits which may be 10 or 15 size.
Apr 25, 2016 at 6:44 AM
  • 8 POSTS
Oops, ty
Apr 25, 2016 at 3:42 PM
HMAC300
  • 48,601 POSTS
see if item 8 in original drawing I sent will pull up if not item 3should then remove screws on item9 then get storage box out to reach screws on armrest. we don't have clear instruction s on this and I really need to play with it to see how to remove it
Apr 25, 2016 at 4:35 PM
  • 8 POSTS
I have tried, will give it another's shot. Thank you !!
Apr 25, 2016 at 5:43 PM
DAWN1035
I have tried & tried...did you ever get yours off? I can't seem to get to the screws either. If you finally got yours off, could you please share? I'm beginning to wonder if it will NEVER come off. Thank you in advance!!
Apr 25, 2017 at 8:15 PM
HMAC300
  • 48,601 POSTS
in pic I originally sent item 3 needs to be removed to get armrest up if there are rivets in it then they need to be removed to get item 3 off then gain access to armrest screws. then rivets need to be reinstalled after repair.
Apr 26, 2017 at 7:00 AM
  • 8 POSTS
No, I was not able to. The diagram shows these screws come out, however the only thing that even resembles a screw is this picture which is actually the spring . I cannot figure out to remove. I finally just recovered the console
Apr 28, 2017 at 11:35 AM
To remove the arm rest you need to remove the lower liner inside of the console. the bolts for the hinge are under that.
May 1, 2017 at 4:09 PM
DAN GRABHORN
If you get the arm rest off, how do you remove the pad from the arm rest to replace the skin?
Jul 19, 2018 at 7:24 AM
Can you upload pictures of what you are talking about? Top and bottom then I can tell you how to get it apart for upholstery.
Jul 19, 2018 at 11:04 AM
