How to recharge A/C condenser after replacement?
2014 FORD MUSTANG
40,000 MILES • 5.0L • V8 • 2WD • MANUAL
CHRIS5=
I need to recharge my A/C condenser after I reinstalled the condenser itself.
Aug 4, 2019 at 3:44 PM
We have a number of things for you to help do this. Here is a guide on how to pull it into a vacuum to remove all the moisture then recharge the system:
Here is a video showing the same thing:
https://www.youtube.com/watch?v=4EqdrBVb0sY
Plus here is another video that is a little more general but all say the same basic information:
https://www.youtube.com/watch?v=C9IvBziFUSo
Let us know if you have other questions and we can help out. Thanks
Dec 3, 2020 at 10:59 AM
GOLIVARRI
I viewed your helpful video and will definitely use it as a guide when replacing my condenser. I have a few questions for you. First does the replacement brand matter? The replacement brands I have seen are TYC, Motorsport and Kool Vue. Second question is which replacement part did you use and how has it worked for you. My vehicle has been without a condenser for almost 4500 miles. Do you thing I've damaged anything else by the system not being charged and dry? Lastly, if you recommend the part you used what is the part number? I would like to thank you for useful video and taking the time to assist me with my problem.
Thanks
George
Dec 3, 2020 at 11:02 AM (Merged)
MLDANIELS2000
  • 227 POSTS
Any system with condensor failure would need orifice tube and accumulator replacement as well. All aftermarket brands from parts stores are good and most come with lifetime warranties at reduced cost. my shop uses mostly parts form O'reillys and Auto Zone. Also flush you system with a/c flush and compressed air to rid lines and evaporator of contaniments. Add new pag oil. Parts stores can pull up what kind and how much when you look up parts based on your vehicle make and model. Just be sure to lightly lubricate new orings at all sealing surfaces or a leak will occur.
HMAC300
  • 48,601 POSTS
if it's been open that long don't forget to put a vacuum pump on it for at least 25 minutes as well.
SLADER1
Hey guys, I watched the video on you tube about replacing the A/C condenser on a 2011 V6 Mustang. Great video. I need to replace mine buts its on a GT500. I have one question. In the video on the V6 why did y'all disconnect the radiator hoses and drain the fluid if you were just replacing the A/C Condenser?
WRENCHTECH
  • 20,761 POSTS
The radiator has to be at least moved if not completely removed. Your car is supercharged and will be quite different from the 6 cylinder mustang.
Here are the factory instructions.
Removal and Installation
All vehicles
With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Vehicle Jacking and Lifting.
Recover the refrigerant.
Remove the 8 upper radiator air deflector pin-type retainers and remove the air deflector.
4.6L vehicles
Remove the Air Cleaner (ACL) outlet tube. For additional information, refer to Fuel Delivery and Air Induction.
5.4L vehicles
Remove the 2 degas bottle bolts and position the degas bottle aside.
All vehicles
Remove the 4 upper radiator bracket bolts and the 2 upper radiator brackets.
To install, tighten to 10 Nm (89 lb-in).
Remove the condenser inlet fitting nut and disconnect the fitting.
Discard the O-ring seal and gasket seal.
To install, tighten to 15 Nm (133 lb-in).
NOTE: The radiator must be positioned rearward to access the 2 upper condenser bolts.
Remove the 2 upper condenser bolts.
To install, tighten to 9 Nm (80 lb-in).
Remove the 9 lower radiator air deflector screws and the lower radiator air deflector.
Remove the condenser outlet fitting nut and disconnect the fitting.
Remove the 2 lower condenser nuts and position the power steering cooler line aside.
NOTE: The condenser core must be removed from below the vehicle.
Remove the condenser core.
To install, reverse the removal procedure.
Install new gasket seals and O-ring seals.
Add the correct amount of clean PAG oil to the refrigerant system. For additional information, refer to the Refrigerant Oil Adding procedure.
Evacuate, leak test and charge the refrigerant system.
LMORGAN3D
  • 5 POSTS
You have a video on condenser replacement, and in the video it said you were going to have another video on Charging an air conditioner system after replacing the condenser. I did not find it, was a video on charging done?
Thanks, Lynn.
SATURNTECH9
  • 30,869 POSTS
There is the link to it your going to want to vacuum the system down since you opened the system to help get the moisture out. Auto zone rents a lot of that stuff depending on the auto zone.
LMORGAN3D
  • 5 POSTS
Thanks for the link to basic recharging. I should have been more specific. The 2010 mustang has a condenser assembly with includes accumulator/dryer. Oil needs to be added back into the system for both components. Any recommendations?
SATURNTECH9
  • 30,869 POSTS
I gave the link for vacuum and recharging you can suck oil in when system is under vacuum.
LMORGAN3D
  • 5 POSTS
When the refrigerant was reclaimed, 2.3 oz of oil was taken out, this number I have. Condenser and Accumulator/Dryer both hold oil that has to be added back in. Are there charts or estimates for the components that are going to be replaced?
SATURNTECH9
  • 30,869 POSTS
Two ounces for the condenser.
LMORGAN3D
  • 5 POSTS
Accumulator/Dryer oil amount?
SATURNTECH9
  • 30,869 POSTS
It says to actually drill a 1/2" hole in the top of the old dryer and measure how much comes out. I would just put in two ounces for that one as well.
LMORGAN3D
  • 5 POSTS
Thank you for the help...
SATURNTECH9
  • 30,869 POSTS
You are welcome keep me posted on how you make out.
