key fob issue
2003 CHEVROLET MALIBU
149,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
LAVARIO PATTON
  • 8 POSTS
Sometimes when I lock the car it will honk. Other times it wont. And sometimes it will even honk on its own just from me putting it in park. Is there a way I can make it permanently lock with the key fob only?
Jul 9, 2016 at 7:06 PM
Its sounds like you have a body control module that is going out which is common on those cars.
Best, Ken
Jul 11, 2016 at 8:40 PM
LAVARIO PATTON
  • 8 POSTS
Just recently, out of nowhere, as I slowed down in a ramp on the freeway, it just cut off and the only reason I was able to tell was because the steering became hard and when I looked everything was off, so I put it in neutral and I turned it off then it started back up. Also when using the cd player it glithces a lot. These are both two symptoms that matches the body control module, but I don't know if it could just be the ignition recall it has.
Jul 17, 2016 at 8:33 PM
The engine stalling would most likely be a separate issue. Here is a guide on what to look for when the engine stalls.
Please let me know what you find
Best, Ken
Jul 18, 2016 at 8:49 AM
