If the pressure readings in the pic are static pressures, that seems high. Keep in mind, that the pressures can be different based on ambient temperature when checked.
However, if the pic above shows static pressure, that is a bit high. If it is accurate, the system is overcharged. See pic 2 below for acceptable static pressures based on ambient temperatures.
As far as the relay, it is in the under-hood fuse box. Remove the relay and inspect it. Each of the four pins will have a number. The numbers are 85, 86, 87, and 30.
You need to locate pins 87 and 30 and where they connect in the box. Those are the two pins that will send power to the compressor (if power is available).
Pin 30 receives power from the compressor clutch 10 amp fuse. So, before jumping it, check that connector to see if there is power. It should be present at all times.
Keep in mind, based on the provided readings, the system may be over-charged. Pay attention to the pressure readings. You don't want a compressor to fail or a hose. Actually, you don't want anything to fail due to high pressure.
Let me know what you find. Also, here is a link you may find helpful for testing the relay and relay circuit:
See pics below.
Sep 7, 2023 at 6:57 PM
