How to hook up obd 1 scanner?
1994 DODGE GRAND CARAVAN
95,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
DAVID CHANDLER FARR
  • 41 POSTS
Where do I hook a obd1 scanner to retrieve transmission fault codes?
May 9, 2025 at 2:26 AM
STEVE W.
  • 15,113 POSTS
You will find that vehicle has two ports. The engine controller access is under the hood that looks like the attached image, it's on the left side inner fender. Then there is the main data bus connection that also has the transmission controller on it that one should be under the dash on the left side it also has 6 pins but in 2 parallel lines like the third image.
May 9, 2025 at 8:00 AM
This guide shows how to get the codes:
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
May 11, 2025 at 11:18 AM
STEVE W.
  • 15,113 POSTS
Just keep in mind that those codes are only the engine codes, not the transmission codes.
May 12, 2025 at 2:06 PM
