How to go around anti theft system
1989 CADILLAC ELDORADO
12,000 MILES
RAINEY ANNE BLANKENSHIP
the anti theft system has shut down the engine from starting how do I go about rewiring it?
Sep 27, 2016 at 5:32 PM
WRENCHTECH
  • 20,761 POSTS
The most common failure in these is the sensor in the ignition lock that reads the key pellet. That would mean replacing the ignition lock with a sensor included.
That sensor can be bypassed. You would need a digital ohmmeter to measure the resistance of the pellet in the key. Now go to Radio Shack and buy a resister of the exact same value as the key pellet. Go to the base of the steering column and locate the two thin white wires that go up to the sensor. Cut the two wires and solder the resister between the two ends coming from the harness. This will permanently bypass the sensor but not the rest of the system.
Sep 27, 2016 at 8:21 PM
