How to get the hazard light to stop flashing
2003 FORD WINDSTAR
180,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
KENNY HARMS
  • 4 POSTS
After I changed my alternator and serpentine belt, I connected the battery cables and the hazard lights were flashing the only way to stop them is to take off the positive battery cable. I have looked for blown fuses, I have pulled every relay, I have locked and unlocked the drivers door with my key. I have looked behind the glove box for a relay there is not one. I cannot keep driving with the flashers going on. what is my next thing to check?
Jan 9, 2018 at 9:49 AM
It sounds like you had a voltage spike that took out something like the instrument cluster which happens. I would try to remove the cluster and unplug it to see if the hazards stop flashing. Here is a hazard light wiring diagram so you can see how the system works. (below)
Jan 10, 2018 at 12:24 PM
