How to get the air out of the cooling system
1997 SUBARU LEGACY
165,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
SAMMAGHIN
  • 9 POSTS
I just put in a new water pump when I was done my heater did not work so I did some research and found that you got to burp them. they recommended spill free funnel so I got one the told me to run my car until no more bubbles. it has been running off and on for the last six hours and still a lot of bubbles. what am I doing wrong?
Nov 5, 2017 at 5:24 AM
CARADIODOC
  • 34,306 POSTS
You aren't opening the system where the air is trapped. That is under the thermostat. Even though the engine has warmed up, for a thermostat to open, it has to be hit with hot liquid. Hot air won't do it.
Most import engines have thermostats with tiny bleed holes in them to allow air to sneak through and go to the radiator. Many replacement thermostats don't have that bleed hole, so you have to manually bleed them. Look for a bleeder screw on the thermostat housing. If you don't find one, look for a sensor or a threaded plug on or near that housing that you can remove. If you have to remove a sensor, you'll need to unplug it. Do that with the ignition switch off to avoid setting a diagnostic fault code that could confuse someone in the near future. Fill the system until coolant runs out, then reinstall the plug or sensor.
Nov 8, 2017 at 5:18 PM
SAMMAGHIN
  • 9 POSTS
There's no bleeding screw on thermostat housing bottom of the radiator thermostat that's connected to the water pump
Nov 8, 2017 at 7:19 PM
CARADIODOC
  • 34,306 POSTS
I'm not familiar with your specific engine but thermostats are rarely next to the water pump. Follow the upper radiator hose to the housing it attaches to and look there.
Nov 8, 2017 at 7:23 PM
SAMMAGHIN
  • 9 POSTS
In my Subaru my thermostat housing sit in side of the water pump
Nov 8, 2017 at 7:26 PM
CARADIODOC
  • 34,306 POSTS
If you're seeing air bubbles coming out of the radiator, you have one of two things, Either air is still self-bleeding and will continue to do that for a while, or the cylinder head gasket is leaking. Does the engine overheat? Did you replace the water pump because it was leaking, or to solve some other problem?
If the engine doesn't overheat, drive the car at highway speed. The higher water pump velocity will help push air out of the heater hoses.
Nov 8, 2017 at 7:44 PM
SAMMAGHIN
  • 9 POSTS
My heater started to work so I thought it was good so I drove around the block and heater went cold again and overheated so I didn't make it that far I changed the water pump because it was leaking and and I was overheating I changed the thermostat at the Same time the water in the spill proof funnel is just warm to the touch I let it cool off and stuck funnel on and more bubbles my oil looking good it not milky looking
Nov 8, 2017 at 9:49 PM
SAMMAGHIN
  • 9 POSTS
It doesn't overheating when the radiator cap is off and it just at an idle I hope it not my head gasket
Nov 8, 2017 at 9:53 PM
CARADIODOC
  • 34,306 POSTS
Your mechanic can perform a chemical test at the radiator to check for a leaking cylinder head gasket. It only takes a few minutes. The test involves drawing air from the radiator, while the engine is running, through a glass cylinder with two chambers partially-filled with a special dark blue liquid. If combustion gases are present, the liquid will turn bright yellow.
Nov 10, 2017 at 3:07 PM
SAMMAGHIN
  • 9 POSTS
Okay
Nov 12, 2017 at 10:48 PM
Here is how to do the test becasue it sounds like a blown head gasket.
Nov 15, 2017 at 6:14 PM
SAMMAGHIN
  • 9 POSTS
I'll go get the tests in the morning I don't have eny of the sign of a blown head gasket but I'll find it resend n the morning
Nov 15, 2017 at 6:48 PM
SAMMAGHIN
  • 9 POSTS
Well it stayed blue it didn't change color so I'm taking it that I don't have a blown head gasket I'm about ready to junk this car or see if I can't get a trade in in it because I can't figure it out thanks for all your help guys
Nov 17, 2017 at 3:44 AM
The head gasket test is only about 80% accurate so you could still have a blown head gasket. If bubbles are constantly being generated then you have a blown head gasket.
Nov 17, 2017 at 12:02 PM
