how to get error codes?
1995 GEO TRACKER
160,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
TRISHABRYANT
tracker will not start.
Apr 10, 2024 at 3:12 PM
I believe this model still used the OBD 1 system in 1995. That was a major transitional time from OBD 1 to OBD 2.
If it does have the OBD 1, here is a link that explains how to retrieve codes. All you will need is a short jumper wire or even a paper clip.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Also, try this for me: See if it will start if you use starting fluid. If it does and then stalls, we will know it is a fuel related issue. If there is no change, I need you to check for spark at the plugs. Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
This will help narrow us down to the correct circuit to focus on.
Let me know what you find.
Apr 10, 2024 at 6:39 PM
