If there is debris in the compressor, you are past the point of trying to save it. The damage has already been done. I have a friend going through this right now with an 2007 truck. I helped him rebuild it six years ago after being hit so hard in the front, it pushed the engine through the firewall. He put on a new compressor and charged the system. Worked fine for four years, then the compressor clutch went out. Another new compressor. This one lasted two years. New compressor again along with a new accumulator and hose with the orifice tube. Worked fine for well over five minutes, then locked up. Replaced under warranty. That one lasted thirty minutes, then locked up.
Finally did an autopsy and found powder and chunks inside. The "wobble plate" had been torn apart causing the powder. After consulting a third expert, it has been learned that most newer condensers can not be flushed effectively. The chunks in it will not usually make it back around to ruin the compressor, but any blockage it forms will severely limit the flow and the cooling efficiency. At this point an entire kit is on order including condenser, compressor, evaporator, accumulator, and all hoses. This is going to be a really major repair.
Why do you think there is debris in the system? Was your old compressor locked up?
Aug 1, 2017 at 6:14 PM
