I've changed the MAF, PCV valve, all emission hoses, cleaned the throttle body and changed the gasket, the spark plugs, and air filter. It's idling rough and at startup the RPMs go almost to two and remain there for a minute. When stopped at a light it doesn't shut off but makes it feel it might any time. Any suggestions on how to fix these codes? Also, my check engine light doesn't light up, but I get codes when i use a scanner, is this normal?
May 4, 2022 at 6:00 AM
