How to diagnose which sensor causing check TOD light?
2002 ISUZU AXIOM
132,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
DEDE MARKUS
I have come across the similar question in this site and I wonder if I can obtain the diagnostic file as I have no clue on how to retrieve the code.
The car is able to drive. No engine light, just check TOD. I bought a VSS sensor already but I guess it might not be the answer yet.
I am willing to donate for the answer :) Although I am not able to donate too much since I am a student. I can buy you a coffee. A lunch I guess.
Quote:
"An error has been detected in the TOD system and you need to retrieve the trouble code to find out what is wrong."
So I guess I need to know how can I diagnose that as I am not sure whether it is the front right/left or rear left/right. Thanks a lot!
Aug 29, 2018 at 2:55 AM
No need for a donation we just want to get to a conclusion is all we ask. The " Torque On Demand" light is telling you reduced power or limp mode. Lets run the codes to see what is going on you can get a code reader from Amazon for $20.00. Here is a guide to help us get started:
Aug 30, 2018 at 10:53 AM
DEDE MARKUS
Hi Ken, I do have a OBD2 reader but it is not able to retrieve the code. I bought that to a mechanic, he said the code can only be read by the dealership as it is not engine light but the TOD light.
Sep 1, 2018 at 2:08 AM
These lights are kind of the same thing both tell you there is a malfunction. Does the code reader not connect or is there no codes?
Sep 1, 2018 at 11:10 AM
DEDE MARKUS
There are no codes. Just the Check Tod light keeps flashing, no codes can be read by the reader.
Sep 1, 2018 at 3:42 PM
It sounds like the throttle pedal sensor and the throttle body have lost their correlation. Disconnect the battery and remove the throttle body for service. This guide will show you how:
Sep 3, 2018 at 12:24 PM
