Using a fuel pressure gauge, attach it to the fuel rail schrader valve. Once installed, turn the key to the run position. At that point the system will pressurize. Check to confirm the pressure is within the manufacturer's specifications.
Another thought, often times a lean fuel mixture is the result of a engine vacuum leak. Check to make sure there are no disconnected, damaged, dry rotted vacuum hoses.
Nov 14, 2017 at 7:17 PM
