Water pump replacement
2007 CITROEN C4
138 MILES • 4 CYL • AUTOMATIC
ZIZO ABOUL EZZ
My car so hot. How to change water pump?
Oct 19, 2017 at 9:19 PM
MHPAUTOS
  • 31,937 POSTS
Before changing the water pump, you need to make sure that that is the problem. I would first be checking for a faulty thermostat, coolant leaks internal and external and cooling fans are working, also that the radiator is not blocked. i suggest this as water pump failure is often well down on the list of actual causes for engine overheating.
Oct 19, 2017 at 11:08 PM
Here is a guide that will let you know what you are in for when doing the job.
https://www.2carpros.com/articles/water-pump-replacement
Nov 1, 2017 at 6:47 PM
