Thanks for the reply and pictures. I had found what I suspected was the drain plug and you confirmed that. I had not located or researched the fill level plug, thanks again for showing that.
I assume the rubber plug on top of the side pan is the fill hole and one fills it until it comes out the fill level plug?
I was planning on pulling the side cover to access and evaluate the "2-4 duty brake duty solenoid" because the vehicle has code P1748 which I have read is "EPC malfunction" and has led me to that solenoid. Also it flashes F then four repeatedly on the instrument cluster
I figure it's probably due for a fluid change anyways.
My daughter bought the vehicle a few months ago w/250,000 kms on it, so we have no history on it. I can tell that the transmission side pan has been removed and replaced previously. (rtv)
Also, what type of fluid is needed for this transmission? Is Dexron III okay?
Aug 31, 2017 at 7:45 AM
