How to change front and rear brake discs on graced scenic
2005 RENAULT SCENIC
1.9L • V8 • TURBO • FWD • MANUAL
LAK SINGH
Can remove everything including the calliper and two nuts that hold that hold the disc but cannot remove the disc. Do I have to undo the hub nut for both front and rear discs
May 26, 2014 at 11:44 AM
The rotor should come off without removing the hub. It may require some persuasion.
May 27, 2014 at 8:51 AM
