how to change a water pump?
1999 OLDSMOBILE ALERO
177,523 MILES
EDWARD LOTZE
We need instructions step by step on what all we need to do to change the water pump.
Apr 21, 2021 at 8:16 PM
HARRY P
  • 2,292 POSTS
Hello. There are two different engines for this car. A 4 cylinder 2.4L engine and a 6 cylinder 3.4L engine. I'm attaching instructions for the 3.4L V6 engine and will follow up with another post regarding the 4 cylinder engine.
Attached you will find screenshots of AllDatas instructions for the job. They do assume a level of experience and mechanical abilities. The link below is a decent YouTube video.
https://youtu.be/FNYBSOeZMSg
I'll gather the 4 cylinder information next.
Apr 21, 2021 at 8:49 PM
HARRY P
  • 2,292 POSTS
For the 4 cylinder engine, the best video I found is actually for another GM car with the same engine. The process should be similar.
https://youtu.be/ifJwqKLJNIQ
Again, I'm attaching AllDatas information on the subject too.
Apr 21, 2021 at 9:02 PM
HARRY P
  • 2,292 POSTS
A couple of tips.
No matter which engine you have, it is vitally important to clean the mounting surfaces and make sure that any remaining old gasket pieces are gone. Failure to do so will result in a leak and having to do it all over again.
Also, I personally always use gasket sealer/maker in conjunction with the proper gasket. This helps seal things up even better as well as helping you to keep the gasket stuck in place. Again, this is optional, but strongly recommended.
Good luck to you. Be sure to come back any time.
Apr 21, 2021 at 9:08 PM
