How to bleed a coolant system
2003 BUICK PARK AVENUE
220,000 MILES • 3.6L • 2WD • AUTOMATIC
DANIELLE STAIRS
  • 11 POSTS
Can anyone tell me how to get the air out of my coolant system I recently had it flushed and now I believe there's some air in it because whenever I sit idle in the car and it's running the air is mildly warm but yet I drive the car and the heater works great.
Jan 21, 2020 at 5:27 PM
STEVE W.
  • 15,113 POSTS
If you look on the top of the thermostat housing you will see the bleed port. Step on is with the engine cold, break that bleeder screw loose, don't remove it though. Next be sure that the radiator is full, then top the overflow bottle up to full cold. Now start the engine, turn the heater on full and let it run until the lower radiator hose starts to get warm, that signals coolant flow through the thermostat. Shut the engine off. Now carefully loosen the bleeder screw. Do not try to remove it or you risk a bath in very hot coolant. You just want to crack it enough that trapped air can get out, you will hear it hissing. When you get only coolant out, Close the bleeder. Now top off the overflow to full hot. Now let the engine cool completely. Top the overflow to full cold if needed. Take it out and drive it and see if there is still air in the system. If yes, repeat the bleeding process.
Jan 31, 2020 at 3:21 PM
DANIELLE STAIRS
  • 11 POSTS
Thank you! I was praying it had a bleeder screw, I really didn't wanna have to put it up on ramps and that's the only other way I know (because my dad taught me that way 15 years ago).
Feb 2, 2020 at 2:07 PM
Good to hear, please use 2CarPros anytime we are here to help.
Feb 4, 2020 at 4:23 PM
STEVE W.
  • 15,113 POSTS
Have used the ramp trick on stubborn ones myself. These days I just use a vacu-fill system, so much easier. If the bleeder hasn't been used it can be tight, so be gentle with it.
Feb 4, 2020 at 5:53 PM
