My car keeps overheating. It seems the antifreeze keeps coming out from the white reservoir. It seems to me that the pressure has cost to push the antifreeze up where the cap or the open hose that is attached with the white reservoir. I know it is not the thermostat because the thermostat hose got warm after certain amount of time. Also, the hose from the engine block that attached with the radiator is also hot and both fans are turning on. Although I did a coolant flush yesterday and that is when the issue started. I am not sure if there is a trap air in the system. I am not sure how to bleed the radiator, but would like some instruction how to bleed an air pocket on a coolant system.
May 18, 2018 at 2:18 AM
