How to bleed brakes
1995 FORD
92,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
ROB BLOCKETT
I just replaced the master cylinder and my brakes still feel squishy. How do i bleed the brakes so my car can stop?
Dec 18, 2016 at 6:58 AM
HMAC300
  • 48,601 POSTS
you probably have air in the ABS unit. you can try a power bleeder otherwise a mechanic will need to hook his scanner up to bleed the system so he can open valves on ABS to bleed it.
Dec 18, 2016 at 8:25 AM
STEVE W.
  • 15,113 POSTS
Did you bench bleed the master cylinder before installing it? Why did you replace it? Does it have ABS?
As for bleeding the brakes -
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
is a way to DIY.
Dec 18, 2016 at 8:40 AM
