The front door would not open. Striker was loose. tried to tighten, bottom screw would not stay. so with some kind of seemingly intelligent thought I decided to unscrew the top screw to see, I do not know, maybe what is behind it? I then heard a bolt or whatever keeps the striker in place fall down into the body between the front and back doors which is largely inaccessible (Argh! ). I pried off the plastic cover, and see that I could probably remove what seems like the seat belt tension-er (?) to access the area and retrieve the keeper(s) that have fallen. So, to keep the striker in place do the screws just screw into independent bolts or is there a custom part that holds both screws, and what would be the best way to secure the striker at this point? (like just get a couple bolts and struggle to hold them in place in order to screw the screws)
Jul 12, 2017 at 6:55 PM
