The parking light fuse is located under the hood in the power distribution center fuse box (see diagram below).
It should be fuse number 11, which is a 15A fuse.
If the fuse if good, then the issue is likely a bad wire. Which will require tracing of the wires to find the short or a bad ground.
Here is a helpful guide:
I have attached wiring schematics below.
Thank you.
Nov 8, 2021 at 2:50 PM
