Hello Ken,
Well, that really sucks! We ended up having to buy a new cv axel for the Acura. I'm telling you, if it ain't one thing it's another with this car. Apparently, when we were removing the axel, it was being stubborn to dislodge, and we didn't know that we shouldn't yank on it. In the process of taking it off, the boot that covers the CV joint broke open, and the joint dislodged from the grooves inside the hub and we got a gooey slippery mess. The way this car is designed, is just ridiculous. I've never encountered a design like it.
What's more, we couldn't get the starter out because whoever was in there last, wrenched down the bolts on the exhaust pipe so tight we couldn't get them off. They must have used an impact to put them on because there is no way that those bolts were on 45 ft. lbs. We were barely able to reach the top bolt of the starter after I removed the heat shroud from the exhaust pipe, and it too was severely over tightened and there was no way we could get an impact on either bolt. Just to reach the top bolt for the exhaust and the starter, we had to use about two feet of extensions and a swivel. Every time my buddy tried to loosen either bolt, the swivel would bind up. We even tried putting tape around the swivel to stabilize it. Then if he was able to get a bite on the bolts, the pressure he had to use was pushing out from under the car.
Anyway, about a year ago, the car wouldn't start at all. And through a YouTube video I found, I learned that there is a wire that is attached by a blade connector. Well, this wire had came off. I think it happened when we put a new alternator on it. Anyway, I checked to see if that wire came off. I discovered that it did, so I tried like hell to reconnect it. It took me nearly two hours to get the wire back on, even with removing the wheel. I'm hoping that when I reconnected the wire, that I didn't actually have the female on the male, but it was only touching. With everything removed, it was much easier to reach that wire. When I reattached it, folded back the boot covering the connecter so I could see the female part to get it on the male firmly.
So keep your fingers crossed that after we get this piece of junk back together, it starts right up. I am planning to sell it after it's back together, regardless if it starts right up or not. I gotta get that thing out of my life. It's literally going to take a shop the get that starter replaced and I can't afford it. I'll use whatever money I get from it to finish fixing my 85 Dodge D150. I almost got it up and running. I only need to replace the shifter linkage seal on the tranny and put new fluid in it and it should be good to go.
Thea
Sep 23, 2024 at 6:17 AM
